Hi Kincony
I have a relayboard that turns relay on when pin goes to GND. I see A16 digital outputs go high when turned on....Can I invert this to make actuve GND ?
Thankyou..Peter
it according to your arduino IDE code.
I am using homeassistant.....how should I configure the output in the YAML to drive the output to ground ?
Thankyou
if you use home assistant, i think you are using ESPHome. just add "inverted: true" in your pins.
# Example configuration entry
number: 25
(09-14-2022, 05:22 AM)admin Wrote: [ -> ]if you use home assistant, i think you are using ESPHome. just add "inverted: true" in your pins.
number: 25
Hello
I dont have a circuit diagram for the v.5 A16 board. I think you've set it up to turn the led on when the output goes to 12V. I have just tried inverted: false and the LED doesnt work. Can you please share the circuit diagram so I can have a look...
Thankyou
