10-22-2022, 04:26 AM
Hi there
I'm trying to get the relays to work on a KC868-A6.
I'm using the KC868-A8 example source code as the basis for this and modified it as shown below:
#include “Arduino.h”
#include “PCF8574.h”
#define I2C_RELAYS_ADR 0x24
PCF8574 pcf(I2C_RELAYS_ADR);
Serial.println(F(“Start Kincony KC868-A6 Relays example…”));
pcf.pinMode(P0, OUTPUT);
pcf.pinMode(P1, OUTPUT);
pcf.pinMode(P2, OUTPUT);
pcf.pinMode(P3, OUTPUT);
pcf.pinMode(P4, OUTPUT);
pcf.pinMode(P5, OUTPUT);
Serial.print(“Init PCF8574… “);
if (pcf.begin()){Serial.println(F(“Ok”));}
else {Serial.println(F(“Error”));}
pcf.digitalWrite(P0, HIGH);
Serial.print(F(“Relay #”)); Serial.print(P0); Serial.println(F(” ON”));
delay(10000);
pcf.digitalWrite(P0, LOW);
Serial.print(F(“Relay #”)); Serial.print(P0); Serial.println(F(” OFF”));
delay(10000);
Using this example, the pcf.begin statement fails and returns "Error".
Looking at the schematic diagram for the KC868-A6, the I2C SDA is set to pin 26, and the SCL is set to pin 23. By default the PCF8574 library will default to other values, so I tried changing the statement below to the following which matches the format noted in the readme file for the PCF8574 library
PCF8574 pcf(0x24, 26, 23);
This didn't work either and so I tried the various I2C scanners and they don't find any I2C device.
I've also ensured that the relevant pins_arduino.h file has been edited to reflect the correct SDA and SCL pin values.
One other thing I have noticed is on startup there is a strange error, see below:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode
IO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13160
load:0x40080400,len:3036
entry 0x400805e4
E (309) i2c: i2c_set_pin(873): scl an⸮4⸮⸮⸮gpio numbers are the same
The highlighted line in red looks odd but I can't find anything online to help.
Any assistance would be appreciated.
delay(10000);
delay(10000);
mode
IO, clock div:1load:0x3fff0030,len:1184
entry 0x400805e4
