Full Version: Tasmota MQTT communication
is it possible to somehow speed up sending statuses via MQTT to Home Assistant? I have the Tasmota firmware installed on the Kincony KC868-A8-v1.5, and if I switch on a relay via the web interface, the change of state is written to me immediately. The problem is with Digital inputs, which are sent in up to 4 minutes. The Tasmota firmware is yours modified in version 10.0.0.3
Thank you for your response
if you use home assistant, we highly recommended to use ESPHome instead of tasmota, ESPHome is very easy and stable for home assistant.
(11-28-2022, 10:36 PM)admin Wrote: [ -> ]if you use home assistant, we highly recommended to use ESPHome instead of tasmota, ESPHome is very easy and stable for home assistant.
Thanks for your reply. ESPHome works very well and is super fast.
ok, you are welcome.
