Full Version: Failed to restart Home Assistant
The system cannot restart because the configuration is not valid: Invalid config for [mqtt]: [name:] is an invalid option for [mqtt]. Check: mqtt->mqtt->switch->2->name:. (See /config/configuration.yaml, line 17).
Quote:Loads default set of integrations. Do not remove.
default_config:
Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
Text to speech
tts:
• platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
broker: 192.168.100.172
port: 1883
username: XXXX
password: XXX
Example configuration.yaml entry
• name: ‘output-1’
unique_id: output-1
state_topic: ‘server/c5a1fc1837679772e927e9de/state’
command_topic: ‘server/c5a1fc1837679772e927e9de/set’
state_on: 1
state_off: 0
• name: ‘output-2’
unique_id: output-2
payload_on: ‘{“relay2”:{“on”:1}}’
payload_off: ‘{“relay2”:{“on”:0}}’
value_template: ‘{{ value_json.relay2.on }}’
state_on: 1
state_off: 0
There is something wrong with your symbol format.
"•" this is not correctly.
can you check attach to find error
thank you
already replied in your another thread. please update one topic in forum.
(12-17-2022, 03:19 AM)admin Wrote: [ -> ]already replied in your another thread. please update one topic in forum.
you can see this topic:
https://www.kincony.com/forum/showthread.php?tid=1998
