Full Version: 868-A4 pins for esphome
Hi
what pins are used for the different input / outputs on the A4?
I would like make the complet unit with capabilities available to home assistant.
Right now i have the following:
  friendly_name: 868-A4
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: "xxxxxxxx"
  password: "xxxxxx"
  ap:
    ssid: "868-A4 Fallback Hotspot"
    password: "xxxxxxxxxxxx"
captive_portal:
    pin: 2
    inverted: false
    pin: 15
    inverted: false
    pin: 5
    inverted: false
    pin: 4
    inverted: false
      number: 36
      number: 39
      number: 27
      number: 14
output:
  - platform: esp32_dac
    pin: GPIO25
    pin: GPIO26
light:
  - platform: monochromatic
    output: dac_output1
    gamma_correct: 2
    output: dac_output2
  - platform: adc
    pin: 34
    update_interval: 5s
dallas:
  - pin: GPIO13
KC868-A4 ESP32 pin define: https://www.kincony.com/forum/showthread.php?tid=282
KC868-A4 for home asisstant ESPHome yaml file: https://www.kincony.com/forum/showthread.php?tid=2036
(03-11-2023, 06:32 AM)admin Wrote: [ -> ]KC868-A4 ESP32 pin define: https://www.kincony.com/forum/showthread.php?tid=282
Thank you for replying.
yes i used the ESPHome yaml file as base for the code above.
But it is missing all the rest of the capabilities.
It would be great to have a esphome template for the KC868-AX with all the hardware capabilities exposed.
This would give new users a good starting point.
actually the ADC,DAC, DS18B20, RF sender and RF receiver functions, we have made many demo yaml on different A series board. you can see different forum zone maybe you will find it. everyl KC868-A model zone, have ESPHome demo code download link.
