Full Version: KC868-A8 Voltage tolerance
Hi! I am planning to use a KC868-A8 in a vehicle, power by battery. What is the input voltage tolerance of the board? Could it handle like, 10-15 volts, or do I have to add a regulator to make sure it gets exactly 12V?
/A A
it use by DC12v, because the power is directly use by Relay's coin. if voltage is higher, it's not good for relay while work long time.
