05-31-2023, 08:27 PM
First, hello All!
I succesfully run my ESPHome project and used almost all available pins on topic board.
I would like also use IR rx and tx pins for uart port for PZEM 004T sensor which works perfectly on my previous esp32 node..
here is piece of code Im trying to use:
I have use also GND and vcc 5V from IR pins but it does not work - is it ok to run uart on these pins? 15 and 2 ?
Regards
tx_pin: 2
rx_pin: 15
baud_rate: 9600
modbus:
#i2c temps and pzem
- platform: pzemac
current:
voltage:
name: "PZEM-004T Napiecie"
power:
energy:
frequency:
name: "PZEM-004T V3 Frequency"
power_factor:
name: "PZEM-004T V3 Power Factor"
update_interval: 60sI have use also GND and vcc 5V from IR pins but it does not work - is it ok to run uart on these pins? 15 and 2 ?
Regards
