Full Version: K868-E16S use digital input and I2C in the same time
I've defined the digital inputs and switches as in the example and also added a DS18B20 temp sensor to the I2C. But as soon as I add in yaml the Dallas configuration, the update_interval toggles the switches on and off at the interval set in the update_interval.
I saw that the I2C port is the same as the Dallas sensor but I don't know how I can connect them in a different way.
  friendly_name: Kincony KC868-E16S
  platform: ESP32
captive_portal:
  sda: 16
  scl: 15
    address: 0x21
    address: 0x25
      pcf8574: pcf8574_hub_out_2
    name: "DI1 - Entrance Left B1"
      pcf8574: pcf8574_hub_in_2
    internal: true
    on_press:
      then:
      - switch.toggle: output14
dallas:
  - pin: 16
    update_interval: 30s
  - platform: dallas
    address: 0x453c430457d4c928
    name: "Livingroom Temperature"
  - platform: dallas
    address: 0x9d3c450457bfc728
    name: "Bedroom Temperature"
DS18B20 can't use I2C bus pin. if you want to use DS18B20, try to use other free GPIO, such as there is a serial port extender on PCB (white 4pin socket).
Thank you for the info, it was a confirmation of what I have to do.
So, I've used RX from the extended serial pin GPIO14.
Also I've added a 4.7K resistor between data and VCC+ (3.3V) of the temp sensor. It's not working without the resistor, that's why it wasn't working yesterday.
dallas:
- pin: 14
update_interval: 10s
Thank you!
RXD:GPIO14
TXD:GPIO33
you can try to use by GPIO14 or GPIO33, if GPIO14 not work, you can try GPIO33.
Hi, I need some help with connecting DS18B20 sensor to E16S, can you make some tutorial or screenshots?
The sensor have 3 wire, but serial on the PCB have 4! Help!
Thx in advance, im begginer!
DS18B20 3 wire: 3.3v, gnd, data. connect these pins with board.
(05-27-2024, 11:44 PM)admin Wrote: [ -> ]DS18B20 3 wire: 3.3v, gnd, data. connect these pins with board.
Where, how? Can you put here some screenshot? Thx in advance!
please search by google, how to use ds18b20
(05-28-2024, 01:45 AM)admin Wrote: [ -> ]please search by google, how to use ds18b20
Are you kidding me? I know how to connect DS18B20 to ESP32, i have a working project on this, but i dont know how to connect DS18B20 tou your PCB(E16S)! NOW you understand? If you can put here some guide or screenshot, is OK, if not, Bye, bye!
