Thank you very much for the continuous updates from your side. This is highly appreciated and speaks to the reliability of your products. However, if it is possible for you to perform updates while retaining the previous settings, it would be even better.
we will try to do that, because some new improvements added, must change the data structure.
(08-22-2023, 02:52 AM)admin Wrote: [ -> ]Here is "KCS" firmware for KinCony KC868-A series (ESP32) board.
How to download and use, online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
v2.1.0 improment:
add IFTTT command for KC868-A64 up to 150
Hi
I made the RS485 command in Custom Protocol for Dimmer D8.
How I can use it in Tuya app?
If I want to make command ALL OFF: 1-64 will be off, but dimmer lamps are still ON
It is working with local wall switch, but not with Tuya app
sorry, i don't understand your question, can you say details.
Software is doing great.!!! its fantastic !!!
Its possible to have more IFFTTT comands?
- I have A64 conected to 64 wall swich i woudl like to configure clic, double click, hold for each. so 192 comands.?
(08-22-2023, 11:25 PM)admin Wrote: [ -> ]sorry, i don't understand your question, can you say details.
Hi
How can control dimmer D8 or KC868-32bs which is connected to A64 board via RS485 connection with Tuya app
(08-23-2023, 02:35 PM)arksop Wrote: [ -> ]Software is doing great.!!! its fantastic !!!
we can try, but too much command, because of limit with memory, maybe system will be not stable.
(08-23-2023, 03:43 PM)Sten Wrote: [ -> ] (08-22-2023, 11:25 PM)admin Wrote: [ -> ]sorry, i don't understand your question, can you say details.
Hi
1. you can update your KC868-H32BS firmware, the newest firmware support Tuya app directly. so you can add KC868-H32BS to tuya app directly (before buy tuya license fro us, here is details:
https://www.kincony.com/forum/showthread.php?tid=2544 )
2. can't use tuya app control KC868-D8 by RS485 bus. KC868-D16 dimmer controller support tuya app directly.
Would to to request KCS for KC868-E16T-V1.2?
