Full Version: How to wire up float switch and use in ESPHome?
Using ESPHOME in Home Assistant.
I have 2 of these float sensor switches. How should I be wiring them up to the board and coding in ESPHome to get an "open/closed"? I thought that they would be an analog device but am not getting any readings.
Or am I using the wrong input?
##################### Analog Inputs
# 2 x DC 0-5V (AI1, AI2)
# 2 x 4-20mA (AI3, AI4)
# GPIO36      ANALOG_A1
# GPIO39      ANALOG_A2
# GPIO34      ANALOG_A3
# GPIO35      ANALOG_A4
# DC 0-5v - ANALOG_A1
      number: GPIO36
#      inverted: true
# DC 0-5v - ANALOG_A2
      number: GPIO39
#      inverted: true
# 4-20mA ANALOG_A3
      number: GPIO34
#      inverted: true
# 4-20mA ANALOG_A4
      number: GPIO35
#      inverted: true
float switch is "binary sensor", so you connect to board's "digital input" port is ok.
Thanks,
Got it hooked up and working now.
####### START digital inputs / physical buttons on board
ok
