How to download and use, online guide:
v2.1.4 improment:
1. fixed KC868-A128 IFTTT bug (can't save >23 IFTTT commands)
2. fixed i2c bus bug for KC868-A8M
3. add support SHT31 i2c temperature & humidity sensor.
4. add auto upload temperature & humidity sensor to TCP server mode or RS232 port.
I'm trying the version 2.1.9 and i canot able to make it work with IFTTT "AND" fonction! I want to set on output 2 (in Jogging mode) when input 5 is "True" and input 2 is "Both Edge".
When we set DI2 in "both Edge" the output do not work...
Can you plan this functions:
- Possibility to save page list length (add setting to store Pageitems length in system menu)
- Possibility to export/import configuration
On IFTTT menu:
- Possibility to duplicate Rule
- Possibility to reorder Rules
- Possibility to add custom description for each Rule
- on list, add short text for IF and Then and not a number
- Possibility to ignore digital input if another specific input is enabled
- Possibility to make condition to do not trigger output if specific output is ON
can you take a screen photo how to set, we can test as your setting.
we will save your suggestion.
(10-01-2023, 09:51 PM)admin Wrote: [ -> ]can you take a screen photo how to set, we can test as your setting.
PLS Add any way to restart timer for one output if the linked input retrigger again between time where the ouput is ON!
and for the suggestion "Possibility to ignore digital input if another specific input is enabled" Perhaps is bether in "then" action to set values in one virutal variable. It is can used condition of input with and function!
the file is attached
Good day everyone, How can i change the BOARD TIME? im using the KC868-A16S v2.1.9... The board time is 1970-1-1 8:36:41, i want to update the date and time.
Thank you..
connect board with internet, board time will auto update from internet. just you need to set the time zone.
(11-11-2023, 08:32 AM)admin Wrote: [ -> ]connect board with internet, board time will auto update from internet. just you need to set the time zone.
the board is already connected to my router LAN and WIFI with internet. but still date and time not updated.
is there other settings i need to change ? network ?
It did not work for me, but i want to share to everyone or to someone who has same board time problem, use time.nist.gov. see pictures.
Thank you admin.
