07-11-2021, 04:03 PM
07-12-2021, 01:09 AM
KC868-COL/COLB/COLB-Mini support use analog sensor that 0-5V output, if you already have 4-20mA sensor. you can use a 250 Ohm resistance connect with signal input port and GND to convert.
To convert a mA analog input signal to voltage you need to attach a inline resistor. The size of your resistor will determine the output range of your voltage.
Resistor Calculations are as follows:
Using ohms law V = R(I) (Voltage = Resistance * Current)
If we were to scale a 4-20mA to 1-5V
For the 0 Value: .004 Amps * 250 ohms = 1 Volt
For the Max Value: .20 Amps * 250 ohms = 5 Volts
02-28-2025, 07:09 AM
i Also have the same sensor and want to connect to my kc-868 server analogue input
the sensor has an output value of 0-10v
please guide me how to use it
03-03-2025, 05:29 AM
KC868-Server analog port only support 0-5v or 4-20mA signal analog sensor.
if you are using 0-10v sensor, you can try to find a convert module on market, let 0-10v convert to 0-5v signal.
03-03-2025, 06:10 AM
the output from the senor is coming from 0-4v but it is not coming on the home assistant
This is my yaml configuration
- sensor:
- name: "Water Level (%)"
state_topic: 'server/42dd7407672e64273d439978/adc1'
unit_of_measurement: "%"
value_template: "{{ ((value | float) * 2) * 10 }}" # Converts 0-10V into 0-100%
- name: "Analog Digital Input 3"
state_topic: "server/7ffd88f939adfbe3340ee686/adc1"
unit_of_measurement: "V"
i am getting no values on home assistant.
my tank is smaller and i am getting values in between 0-5v maximum
- sensor:
03-03-2025, 06:59 AM
i think the mqtt topic only use for digital input and digital output ports, not by ADC.
you can use state_topic: 'server/42dd7407672e64273d439978/state' to check whether have value feedback.
03-04-2025, 05:34 AM
i changed it still there are no values coming to it
03-05-2025, 12:16 AM
take a photo of your mqtt state feedback message.
03-14-2025, 05:26 AM
here is the data received at analogue input 2
here is the change in data too
from 88 to 84
from 88 to 84
