do you have training / description / example focused to modbus ussage in KCS and commnucation implementable to HomeAssistant? I would like to read data over RS485 (ideally more register addressess) via KC868-A8S and transfer them to HomeAssistant.
Regards
Radovan
This is with ESPHome, is it possible also with KCS FW?
i did try to configure using ESPHome. Working ok, configuration via KCS is no more needed. Input / output are the same as on KC868-A8, right? I have downloaded IO pin description from ESPHome from file ( Made_for_ESPHome_KC868-A8.zip ) in this thread -
https://www.kincony.com/forum/showthread.php?tid=1745
Below attaching configuration for A02 ultrasonic distance sensor + KC868-A8S connected via ethernet, maybe this will be useful also for anybody else who want to measure water level in tank :-)
platform: ESP32
sda: 4
scl: 5
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.17
gateway: 192.168.1.1
subnet: 255.255.255.0
- id: 'pcf8574_hub_in_1' # for input channel 9-16
# Individual outputs
pcf8574: pcf8574_hub_out_1
tx_pin: 33
rx_pin: 32
baud_rate: 9600
stop_bits: 1
parity: NONE
modbus:
uart_id: mod_bus
modbus_controller:
- id: kc868_a8s
address: 0x01
modbus_id: modbus1
setup_priority: -10
update_interval: 30s
- platform: modbus_controller
modbus_controller_id: kc868_a8s
register_type: holding
address: 0x0101
unit_of_measurement: "m"
value_type: U_WORD
accuracy_decimals: 0
address: 0x0102
unit_of_measurement: "°C"
value_type: U_WORD
filters:
- multiply: .1
ota:
password: VerySecretPassword
thanks, exactly you not need to use KCS, only use ESPHome to config is enough.
