02-23-2024, 04:12 AM
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574(0x27,4,5); //4 is SDA 5 is SCL need replace by your board's pin define
A0 A1 A2
0 0 0 =0x20
0 0 1 =0x21
0 1 0 =0x22
0 1 1 =0x23
1 0 0 =0x24
1 0 1 =0x25
1 1 0 =0x26
1 1 1 =0x27
unsigned long timeElapsed;
// pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
if (pcf8574.begin()){
Serial.println("OK");
}else{
Serial.println("KO");
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
delay(300);
}arduino code download:
[attachment=4327]
PCF8574 arduino library ZIP file download:
[attachment=4328]
