Full Version: Lesson23- How to connect RGB LED strip using ESP32 by KC868-A4 A8
LED Strip chip model: WS2812B
every LED have R,G,B colors:
every LED cost R: 20mA+G: 20mA+B: 20mA=60mA
if you using 1 meter = 30 LEDs
total cost:60mA*30=1800mA=1.8A  so chose DC5V 2000mA power supply
if you using 10 meter, so will use 300 LEDS
total cost:60mA*30*10=18000mA=18A  so chose > DC5V 18A power supply
-------------------ESPHome Config---------------------------------------------
  platform: ESP32
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "KC868-A4 Hotspot"
    password: "12345678"
captive_portal:
  password: "1"
ota:
  password: "1"
web_server:
  port: 80
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO13    # Pin Define connected with LED strip
    num_leds: 30  #LEDs number
    rgb_order: GRB
    effects:
      - addressable_rainbow:        ##defined 7 effects styles
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
 led strip chip model: WS2811 use DC12V
powe supply DC12V  power supply not DC5V
CAN i use these model with A4 model ?
you can confirm with your LED strip supplier, whether the LED strip DATA pin is 5v level, if it is, ok no problem with A4 module.
Do you meaning pin data shoud be  5 volt?
yes.
im getting an error using this script "warning esp_intr.h is deprecated, please include esp_intr_alloc.h instead"
you can update your ESPHome to newest, test again, if have problem, please upload your screen photo.
Can I do the same using the analog inputs of KC868-A32?
yes
Thank you!
What if I wanted to control (and dim) a regular LED strip that has a power supply like this one? Can I do that witch a32 too?
