KC868-A8 TCP -Server - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KC868-A8 TCP -Server (/showthread.php?tid=8207) |
RE: KC868-A8 TCP -Server - admin - 07-19-2025 ok, we will test with KC868-A8 board , then feedback to you. RE: KC868-A8 TCP -Server - admin - 07-19-2025 i have tested KC868-A8 with KCS 2.2.14 firmware. use command: RELAY-SET-255,8,0 RELAY-SET-255,8,1 sent more than 10 times, all work well. can you take a video how you test and send to whatsapp number: +86-15381188302. i can test as your video. RE: KC868-A8 TCP -Server - Dm81 - 07-21-2025 (07-19-2025, 05:25 AM)admin Wrote: i have tested KC868-A8 with KCS 2.2.14 firmware. use command: I'm testing some changes in the software, It's looks like better I will back to you in case of problem thank you very much foryour support RE: KC868-A8 TCP -Server - admin - 07-21-2025 ok RE: KC868-A8 TCP -Server - Dm81 - 07-29-2025 (07-21-2025, 09:23 PM)admin Wrote: ok hello the changes in software looks like good, no problem at the moment thank you RE: KC868-A8 TCP -Server - admin - 07-29-2025 ok, good. |
