ESPHOME and KC firmware - Printable Version
+--- Forum: "KCS" v2 firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40)
+--- Thread: ESPHOME and KC firmware (/showthread.php?tid=8283)
ESPHOME and KC firmware - fdcemb5 - 07-01-2025
I am trying to configure A32 Pro. Can ESPHome YAML coexist with KC firmware? That's installing ESPhome yaml and flash KC firmare at the same time?
RE: ESPHOME and KC firmware - admin - 07-01-2025
KCS and ESPHome can't work at the same time.
if you don't know how to config by ESPHome, suggest use KCS v3 firmware directly, it's easy to use.
RE: ESPHOME and KC firmware - fdcemb5 - 07-01-2025
If I use KCS v3 firmware directly, how can I integrate with Home Assistant? Kindly send me the link for thew two options
it's very easy use home assistant with KCS v3. only need enable mqtt auto discovery for home assistant.
[Image: protocol-general.png]
here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html
