Z1 Transmit action from. Home Asssistant - Printable Version
+--- Forum: KC868-AG / AG Pro / AG8 / Z1 (https://www.kincony.com/forum/forumdisplay.php?fid=30)
+--- Thread: Z1 Transmit action from. Home Asssistant (/showthread.php?tid=8679)
Pages: 1 2
Z1 Transmit action from. Home Asssistant - paulbalinnel - 10-26-2025
Hello, please describe the best way to send an action from HA for RF to be transmitted from Z1.
Currently, I have a TV lift with a remote that has UP, STOP, and DOWN buttons. I have already programmed these as RF1, RF2, and RF3 in KCS. However, they appear in HA as binary sensors, not switches.
TCP and HTTP?
Thanks
RE: Z1 Transmit action from. Home Asssistant - admin - 10-26-2025
learned RF signal, then you can transmit from KCS monitor webpage. Then create a MQTT switch in home assistant, send MQTT message for learned RF signal. here is mqtt protocol: https://www.kincony.com/forum/showthread.php?tid=7619
RE: Z1 Transmit action from. Home Asssistant - paulbalinnel - 10-26-2025
(10-26-2025, 10:52 AM)admin Wrote: learned RF signal, then you can transmit from KCS monitor webpage. Then create a MQTT switch in home assistant, send MQTT message for learned RF signal. here is mqtt protocol: https://www.kincony.com/forum/showthread.php?tid=7619
Thank you! this will work for me!!
also you can wait for about 1 week. KCS v3 will release new firmware, that will auto create learned IR or RF as a "switch" and auto discovery by home assistant.
RE: Z1 Transmit action from. Home Asssistant - paulbalinnel - 10-27-2025
(10-26-2025, 07:55 PM)admin Wrote: also you can wait for about 1 week. KCS v3 will release new firmware, that will auto create learned IR or RF as a "switch" and auto discovery by home assistant.
SUPER!  Well done, I will wait for this!!!
RE: Z1 Transmit action from. Home Asssistant - paulbalinnel - 11-07-2025
Thank you I did load the new KCSV3 however, the RF is still a binary sensor, not a switch in HA.
Pls look at these remote and frequency, I am not able to learn this RF remote
any advice pls
entities:
  - entity: binary_sensor.kincony_z11_rf1_2
  - entity: binary_sensor.kincony_z11_rf2_2
  - entity: binary_sensor.kincony_z11_rf3_2
RE: Z1 Transmit action from. Home Asssistant - admin - 11-08-2025
do you have learned RF signal successfully in KCS webpage?
RE: Z1 Transmit action from. Home Asssistant - paulbalinnel - 11-08-2025
(11-08-2025, 12:49 AM)admin Wrote: do you have learned RF signal successfully in KCS webpage?
I have 3 remotes
A - RF for TV LIFT (successfully learn in KCS web)
B - RF for Blinds (successfully learn KCS web)
C - Fan Remote (not successful in KCS, picture of remote above, and the frequency, on another project it was successful learn with Bond Bridge)
*The fan is DC brushless motor so can not do AC control
these A and B whether have auto created "button" on KCS monitor webpage?
RE: Z1 Transmit action from. Home Asssistant - paulbalinnel - 11-09-2025
yes i do have the buttons in KCS
