F8 physical on device switches - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F8 (https://www.kincony.com/forum/forumdisplay.php?fid=79) +--- Thread: F8 physical on device switches (/showthread.php?tid=8904) |
F8 physical on device switches - asalhi - 01-12-2026 Hello KinCony, I have a question about the physical switch exists on the device itself, I need to be able to change their behavior to toggle switch instead of normal switch. I mean to toggle the relay state (on -> off, or off -> on) once it is flipped. btw, thank your for such awesome devices. RE: F8 physical on device switches - admin - 01-12-2026 sure, it's ok, just download KCS v3 firmware, set by IFTTT. INPUT toggle OUTPUT. RE: F8 physical on device switches - asalhi - 01-12-2026 Thanks for the reply, I have as Installed the newest firmware, as seen in this image and the IFTTT screen but I cannot figure out how to do it! RE: F8 physical on device switches - admin - 01-12-2026 draw DI and draw DO. here is KCS v3 online guide, you can see how to use IFTTT firstly: https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html |
