08-08-2022, 11:06 AM
I am currently trying to connect a controller with 16 channels through esphome modbus communication.
https://esphome.io/components/modbus_controller.html
Tried with this example but failed.
uart:
tx_pin: 17
rx_pin: 16
baud_rate: 115200
stop_bits: 1
Are the tx and rx pin numbers correct?
What part should I edit?
I really need your help.
We are preparing a plant factory, so if this succeeds, we plan to continue ordering 16-channel boards in the future.
to be able to help
Load the controller Modbus sheet.
http://www.koreadigital.com/pages/sensec...load_1.pdf
uart:
tx_pin: 17
rx_pin: 16
baud_rate: 115200
stop_bits: 1
to be able to help
