02-16-2023, 03:12 AM
Hi all,
I want to measure Carbon dioxide PPM levels using the MH-Z19B sensor with my KC868-A4. The sensor uses UART and that means I need to use IO17 (#28 U2T) and IO16 (#27 U2R) but these are being used in the RS232 connector:
I see that I can easily use the IO16 (Number 9 from above picture) from the DB9 connector, but I don't know what is happening to IO17 (Number 10 from above picture).
To summarize my question, how can I utilize IO17 and IO16 from a KC868-A4 board? Is it even possible to use MH-Z19B sensor with it? I'm using Tasmota on it.
I'm apologize if this is a dumb question, I'm new to all this.
Thank you in advance
