04-15-2024, 08:39 PM
I would therefore need 2 Tuya adapters.
Is it not possible to make them work via the h32L LAN without using wifi?
KinCony Cloud Server will stop service in 2025 upgrade to TUYA app
04-15-2024, 10:18 PM
how many relay controller you have, so that use how many tuya adapter.
H32L use ethernet, tuya adapter use wifi connect to your router.
04-16-2024, 04:45 AM
I have two h32L (more in COL). I'd like to use wired only for best performance
04-16-2024, 04:55 AM
it's ok, use by RS232 cable.
04-16-2024, 07:19 PM
so can I split the rs232 cable? I already use the long range input terminal block
04-16-2024, 10:40 PM
if you want use switch terminal board, it already used RS232 port, so tuya adapter can't use RS232, i have said, control by network for tuya adapter is ok.
