10-22-2024, 05:25 AM
KinCony ESP32-S3 voice assistant based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It use by I2S INMP441 microphone and MAX98357A amplifier. SD card socket on PCB. there are WS2812B RGB LED you can use for assistant. It also have IR receiver and many free GPIOs on PCB.
![[Image: AS1_pix400.jpg]](https://www.kincony.com/images/AS/AS1_pix400.jpg)
![[Image: AS2_pix400.jpg]](https://www.kincony.com/images/AS/AS2_pix400.jpg)
![[Image: AS3_pix400.jpg]](https://www.kincony.com/images/AS/AS3_pix400.jpg)
![[Image: AS4_pix400.jpg]](https://www.kincony.com/images/AS/AS4_pix400.jpg)
Model No. KinCony AS
Description: KinCony ESP32-S3 voice assistant – AS
Power supply: 5V DC by USB cable
interfaces: WiFi,Bluetooth,USB-Mini
SD Card: inside of BOX
WS2812B RGB LED: 2 different channel of GPIO
IR receiver: HS0038
433M receiver PCB pins reserved
Microphone: INMP441 (I2S bus)
Amplifier:MAX98357A (MAX:3.2W)
free GPIOs for DIY extend: 13 pins
hardware details:
![[Image: 5.jpg]](https://www.kincony.com/images/AS/5.jpg)
![[Image: 7.jpg]](https://www.kincony.com/images/AS/7.jpg)
![[Image: 6.jpg]](https://www.kincony.com/images/AS/6.jpg)
![[Image: 8.jpg]](https://www.kincony.com/images/AS/8.jpg)
![[Image: esp32-s3-wroom-1u.JPG]](https://www.kincony.com/images/AS/esp32-s3-wroom-1u.JPG)
software solution:
1. install Speech-to-text add-on “faster-whisper” on home assistant.
2. install Text-to-speech add-on “piper” on home assistant.
3. download AS’ ESPHome yaml file from KinCony forum, modify wifi router SSID and PASSWORD.
4. download firmware to AS(ESP32-S3).
5. begin use in home assistant.
Easy integrate KinCony ESP32-S3 voice assistant to home assistant by ESPHome. You can download yaml file from KinCony forum.
![[Image: voice-assistant-ready.png]](https://www.kincony.com/images/AS/voice-assistant-ready.png)
IR receiver: HS0038
hardware details:
software solution:
