04-16-2025, 06:07 AM
Good day how do I connect a DS18B20 temperature sensor to a KC868-A6 so that I can monitor it through smart home app
DS18B20 temp sensor
04-16-2025, 06:53 AM
smart home app not support tuya. you can use tuya app, that can monitor sensor data. just need tuya license, so that can work with KC868-A6
04-16-2025, 12:16 PM
04-16-2025, 10:05 PM
Do you seen the GND, gpio-1 or gpio-2, 3.3V that use for DS18B20. GPIO-1 means: GPIO32 GPIO-2 means: GPIO33
04-17-2025, 06:08 AM
Ok Thank you very Much
04-19-2025, 11:05 AM
I managed to connect the Temperature sensor and it works perfectly.
Now I have another problem. I have connected a 0-5v pressure sensor to AI1 now I want DO3 to be switched on when AI1 > than 0.2 and DO3 be switched off when AI1 < 0.19 I have created IFTTT scenes but it doesnt want to trigger DO3 on or off. Pleas assist
05-30-2025, 11:04 PM
KS868-A6 for temperature measurement with SD16B20:
I need to help. I have a KS868-A6 with SD16B20 sensor and SSD 1306 display and I want show data on display. I use Arduino IDE. How I can do it? Thank's.
05-31-2025, 12:42 AM
this need you write your own arduino code. we have arduino demo source code for DS18B20 and SSD1306. You need to combine these two parts of code together.
| 1 Guest(s) |
