KC868-Server WiFi Disable.
Question
Good morning, I would need to disable the wifi part of the system, as the device must be installed in an area where the presence of wifi systems is not authorized for security reasons. The entire operation of the system is entrusted to physical wiring. Is there such a possibility and how should I proceed? Thank you in advance.
you can remove the wifi SMA cable , just open the BLACK metal box. remove the SMA-IPEX cable from box.
