No Ethernet, No WiFi, No serial
After receiving the KC868-A128, I flashed it with KC868-A128-HA-input-toggle-output.yaml and everything was working. I powered it off and put it aside because I didn’t have time to install it at the target location.
Today I wanted to continue, but only the red LED next to the power supply is on. The LEDs at the Ethernet connector are not flash, and there are no lights on the switch either. I connected a USB cable, but no serial port is detected on either Windows or macOS. What should I do?
regards,
Toper
take a video of your problem, send to whatsapp number: +86-15381188302
