KinCony Pi5M16 – Raspberry Pi CM5 IoT Gateway released
KinCony Pi5M16 – Raspberry Pi CM5 DIN Rail MOSFET Controller for Smart Home & Industrial Automation
[Image: Pi5M16-1.jpg]
Product Overview
KinCony Pi5M16 is a powerful Raspberry Pi-based IoT gateway designed for smart home automation and industrial control applications. Powered by the Raspberry Pi Compute Module 5 (CM5), it integrates 16-channel MOSFET outputs, optocoupler-isolated digital inputs, analog inputs, RS232/RS485 communication interfaces, PWM outputs, and multiple expansion interfaces into a compact DIN rail aluminum enclosure.
Pi5M16 is an ideal solution for automation projects requiring reliable DC load control. The CM5 directly manages MOSFET outputs, digital inputs, analog inputs, PWM outputs, and serial communication ports, making it easy to develop applications using Node-RED, Home Assistant, Python, MQTT, Modbus, and other Linux-based software platforms.
[Image: Pi5M16-5.jpg]
Key Features
  • Powered by Raspberry Pi Compute Module 5 (CM5)
  • 16-channel MOSFET outputs
  • 16-channel optocoupler-isolated digital inputs
  • Supports Home Assistant and Node-RED
  • RS232 and RS485 communication ports
  • 2-channel PWM outputs
  • 2 × DC 0-5V analog inputs
  • 2 × 4-20mA analog inputs
  • 20 free GPIO expansion ports
  • Gigabit Ethernet support
  • M.2 M-Key PCIe expansion socket
  • DIN rail installation
  • SSD1306 I2C OLED display
  • Industrial aluminum enclosure
  • Ideal for smart home and industrial automation projects
[Image: Pi5M16-7.jpg]
