05-04-2023, 06:14 AM
(This post was last modified: 05-06-2023, 01:04 AM by KinCony Support.)
#include "FS.h"
#include "SD.h"
#include "SD_MMC.h"
#define BOARD_HAS_1BIT_SDMMC
void WriteFile(fs::FS &fs, const char *path, uint8_t *buf, int len)
//unsigned long start_time = millis();
Serial.printf("write [%s]...\n", path);
File file = fs.open(path, FILE_WRITE);
if (!file) {
Serial.println("Failed to open file for writing");
return;
if (!file.write(buf, len)) {
Serial.println("Write failed");
return;
file.flush();
file.close();
Serial.printf("Write [%s] Complete", path);
void ReadFile(fs::FS &fs, const char *path, uint8_t *buf, int len)
Serial.printf("read [%s]...\n", path);
File file = fs.open(path);
if (!file) {
Serial.println("Failed to open file for reading");
return;
if (!file.read(buf, len)) {
Serial.println("Read failed");
return;
file.close();
Serial.printf("Read [%s] Complete: %s", path, buf);
void testIO(fs::FS &fs)
char buf[] = "hello world";
WriteFile(fs, "/test.txt", (uint8_t *)buf, strlen(buf));
ReadFile(fs, "/test.txt", (uint8_t *)buf, strlen(buf));
pinMode(2,INPUT_PULLUP);
// put your setup code here, to run once:
Serial.println("Please insert SD card");
delay(1000);
/* SD_MMC 1-bit Mode */
if (!SD_MMC.begin("/cdcard", true)) {
Serial.println("Card Mount Failed");
return;
testIO(SD_MMC);
SD_MMC.end(); // cancel SD card mount
}after program running, we will find "hello word" have wrote to txt file and saved SD card.
SD card use by "1BIT_SDMMC" work mode.
