06-22-2021, 02:34 PM
I understand that the built-in relays might get worn and have to be replaced after a few years of operation.
1. What is the model/specifications of the relay units installed in the actuator? Can it be soldered (out and in) easily at home with a simple solder, or does it require special equipment/specialty? Do these relays getting worn when sitting on the shelf unused? I consider buying a few relay units in advanced and store them at home for such case.
2. Can I replace these relays with higher quality ones?
3. How much does using a secondary contactor enlarges the life expectancy of these built-in relays? What is the most recommended contactors? Are SSR contactors preferable over magnetic ones? Does it wore them less if they operate on DC12V?
4. Is it recommended to use RC snubber for SSR contactors or it is relevant only for magnetics?
Thanks,
Elad
Thanks,
Elad
