10-03-2023, 09:53 AM
What is the maximum length of cable run that can be supported for a clamp sensor and still receive accurate readings?
Thanks
Thanks
Cable length run?
Thanks
10-03-2023, 01:12 PM
how many distance you want to use?
10-04-2023, 12:32 PM
Which current clamps do you advise for this board?
Can you send the link to the store/product?
10-05-2023, 12:34 AM
usually use about 1-2 meter, here is CT clamp sensor have supportted:
https://www.aliexpress.com/item/1005005527700418.html
11-04-2023, 09:29 PM
(10-03-2023, 09:53 AM)deanfourie Wrote: What is the maximum length of cable run that can be supported for a clamp sensor and still receive accurate readings? If you need longer clamp sensor cables, would be best to get them in the mA output version. Idea being that the current output doesn't change over wire length, whereas the voltage does.
11-05-2023, 12:10 AM
yes, "current" type for long distance cable. "voltage" will reduce when cable very long.
| 1 Guest(s) |
