11-20-2024, 11:38 AM
I am facing an issue with my KC868-A4S relay controller. When I connect the device to a PC via a USB-C cable, the PC does not recognize it. The red light on the device turns on when powered, but there’s no indication that the USB-C connection is active, and the COM port does not appear.
Here are the steps I’ve tried so far:
Could you please guide me on how to resolve this issue? Additionally, if the device itself is not working, is there a way to verify whether the hardware is functioning correctly or an alternative method to test it?
Looking forward to your suggestions.
Thank you!
- Tested with 3-4 different Type-C data cables but still couldn't detect the COM port on the PC.
- Installed the USB driver from this link before attempting the connection.
Thank you!
