12-07-2024, 05:40 AM
DHT22 use by 3.5v--5.5v power. so i have contact with 433MHz receiver's pin, that have a 5V point.
platform: ESP32
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
address: 0x24
address: 0x25
address: 0x21
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
# Use pin number 0
# One of INPUT or OUTPUT
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_out_2
# Use pin number 0
mode: OUTPUT
inverted: false
pcf8574: pcf8574_hub_in_1
# Use pin number 0
inverted: false
pcf8574: pcf8574_hub_in_2
# Use pin number 0
inverted: false
- platform: dht
pin: 32
temperature:
humidity:
name: "Living Room Humidity"
update_interval: 60s
web_server:
port: 80
