KC868-H32B momentary switch self reset
I am facing issue with KC868-H32B relay settings, when i enable relay momentary timer for more than 10 relays, entire settings reset.
Relay setting, password setting all gone.
Chip module is GD32F103
Firmware version H32B_V4.37
Any idea what could be the problem ?
can you re download your firmware for a testing.
i re-downloaded again from the forum, re-flashed again into the board and result is same.
I can enable momentary only 1 , 2, 25 - 32 anything else remove them all.
can you take a video of your problem, send to whatsapp number: +86-15381188302
