01-18-2025, 04:23 PM
I have been trying for a few days to set up the KC868-ATC v1.4 with Tuya module to connect to KC868-H32 rev 2.3 and control the relays. I managed to set the KC868-ATC Tuya module and connect using Tuya mobile App (Android), however the button/switches are not responding.
The weird part is that I can connect to KC868-H32 using Vircom and the IP seems to be set to 192.168.2.160 (we are using 192.168.2.x ranges). From what I have seen in the referred videos is that I should also be able to connect using the browser however this is failing. KC868-H32 is connected to the router through Ethernet cable
I have even tried to set KC868-ATC v1.4 to use RS232 instead of wifi. This had the same negative results.
If you require more information please let me know.
Please help me with some ideas how to set this system. I assume that I might have to change the firmware on KC868-H32 as in Tuya it was showing H32B PRO
Thank you very much and I wish you a great day
