11-16-2025, 12:28 PM
When using HA Auto Discover with KCS 3, should the analog inputs be detected and shown in Home Assistant? I'm only getting the digital inputs. Or do I need to use ESP Home?
Analog Inputs via MQTT HA Auto Discover
11-17-2025, 02:05 AM
what KCS v3 frimware you have downloaded? use for F16? analog input should found in Home Assistant.
if you want use ESPHome, also is ok for analog input ports.
| 1 Guest(s) |
