kincony a16 modbus + WallPad wall switch
Hello
I need help with setup wallpad using modbus:
google drive with manual:
https://drive.google.com/drive/folders/1...drive_link
i have some errors, code from aiSmile
[17:49:15.467][D][modbus_controller:039]: Modbus command to device=2 register=0x100B no response received - removed from send queue [17:49:15.705][W][modbus_controller:284]: Duplicate modbus command found: type=0x4 address=4107 count=1
any user tryed this wall pad?
  platform: ESP32
wifi:
  ssid: "YOUR_WIFI"
  password: "YOUR_PASSWORD"
  baud_rate: 0
ota:
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 9600
  stop_bits: 1
modbus:
  uart_id: rs485_uart
modbus_controller:
  - id: wallpad
    address: 0x02
    modbus_id: modbus1
    setup_priority: -10
    update_interval: 200ms
# RELAYS (Kincony A16)
    pin: GPIO32
    on_turn_on:
      - script.execute: led_1_on
    on_turn_off:
      - script.execute: led_1_off
    pin: GPIO33
    on_turn_on:
      - script.execute: led_2_on
    on_turn_off:
      - script.execute: led_2_off
    pin: GPIO25
    on_turn_on:
      - script.execute: led_3_on
    on_turn_off:
      - script.execute: led_3_off
    pin: GPIO26
    on_turn_on:
      - script.execute: led_4_on
    on_turn_off:
      - script.execute: led_4_off
# BUTTON INPUTS (RS485)
  - platform: modbus_controller
    modbus_controller_id: wallpad
    register_type: holding
    address: 0x100B
    bitmask: 0x0001
    on_press:
      - switch.toggle: relay_1
    address: 0x100B
    bitmask: 0x0002
    on_press:
      - switch.toggle: relay_2
    address: 0x100B
    bitmask: 0x0004
    on_press:
      - switch.toggle: relay_3
    address: 0x100B
    bitmask: 0x0008
    on_press:
      - switch.toggle: relay_4
# LED CONTROL SCRIPTS
script:
  - id: led_1_on
    then:
      - modbus_controller.write_register:
          address: 0x1008
          value: 0x0101  # White LED ON
  - id: led_1_off
    then:
          address: 0x1008
          value: 0x0001  # Yellow LED
  - id: led_2_on
    then:
          address: 0x1008
          value: 0x0102
  - id: led_2_off
    then:
          address: 0x1008
          value: 0x0002
  - id: led_3_on
    then:
          address: 0x1008
          value: 0x0104
  - id: led_3_off
    then:
          address: 0x1008
          value: 0x0004
  - id: led_4_on
    then:
          address: 0x1008
          value: 0x0108
  - id: led_4_off
    then:
          address: 0x1008
          value: 0x0008
sorry, we have not used that switch panel, you can read button by modbus, then toggle A16 output.
