02-10-2026, 09:57 AM
I am experiencing two possibly related issues with my Kincony A-128 controller.
Issue 1 – Digital Output LEDs glowing when OFF
Some Digital Output LEDs are glowing dimly even when the outputs are OFF in the control panel.
When I turn an output ON, the LED becomes much brighter (normal behavior).
Details:
Issue 2 – Module freezes when switching all outputs ON
When I use Home Assistant and press a button that turns all relays ON at once, the following happens:
Load and power details
Questions
I can also provide:
Best regards
Details:
- One section has 8 LEDs dimly ON
- Another section has 4 out of 8 LEDs dimly ON
- The remaining 14 sections work correctly
- The issue always affects the same sections
- LEDs are visible directly on the board
- I may have accidentally caused a short circuit on these outputs during wiring
- The module freezes
- All channels turn OFF
- Home Assistant shows the device as offline
- The module does not reconnect automatically
- I have to disconnect power completely and power it on again for Home Assistant to discover it again
- If I turn the outputs on slowly / step by step, the problem does not occur
- The problem only appears when switching many outputs ON simultaneously
- Most outputs are connected to 6A relays
- Some outputs are connected to WAGO 16A relays (higher current consumption)
- All relays and the A-128 module are powered from the same 24V power supply
- Control voltage and relay supply voltage are both 24V
Questions
- Could the dimly glowing LEDs indicate damaged output channels?
- Could the freeze/offline behavior be caused by power supply overload or voltage drop when switching all outputs at once?
- Is this a known behavior of the A-128 when driving many relays simultaneously?
- Has anyone experienced similar issues with A-128 and Home Assistant?
I can also provide:
- Firmware version
- Power supply specifications
- Voltage measurements during switching
Best regards
