ESPHome configure for KC868-A8:
function list:
1. 8 relay output
2. 8 switch input trigger relay output by on_press action
3. monitor 2 channel analog input for DC
4. TEMP-1 port: 2 channel DS18B20 temperature sensor use by 1 ports, actually, you can connect multi DS18B20 by one wire.
5. TEMP-4 port: WS2812B LED strip for 1 meter (30 LEDs)
6. network by Ethernet cable
platform: ESP32
ota:
password: "bfb55afbf347b27a4bda0a1d36ee994f"
web_server:
port: 80
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.199
gateway: 192.168.1.1
subnet: 255.255.255.0
- id: 'pcf8574_hub_output'
address: 0x24
- id: 'pcf8574_hub_input'
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_output
# Use pin number 0
# One of INPUT or OUTPUT
mode: OUTPUT
# Use pin number 0
mode: OUTPUT
# Use pin number 0
mode: OUTPUT
# Use pin number 0
mode: OUTPUT
# Use pin number 0
number: 4
mode: OUTPUT
# Use pin number 0
number: 5
mode: OUTPUT
# Use pin number 0
number: 6
mode: OUTPUT
# Use pin number 0
number: 7
mode: OUTPUT
pcf8574: pcf8574_hub_input
# Use pin number 0
inverted: false
on_press:
then:
- switch.toggle: switch1
# Use pin number 0
inverted: false
on_press:
then:
- switch.toggle: switch2
# Use pin number 0
inverted: false
on_press:
then:
- switch.toggle: switch3
# Use pin number 0
inverted: false
on_press:
then:
- switch.toggle: switch4
# Use pin number 0
number: 4
inverted: false
on_press:
then:
- switch.toggle: switch5
# Use pin number 0
number: 5
inverted: false
on_press:
then:
- switch.toggle: switch6
# Use pin number 0
number: 6
inverted: false
on_press:
then:
- switch.toggle: switch7
# Use pin number 0
number: 7
inverted: false
on_press:
then:
- switch.toggle: switch8
dallas:
- pin: GPIO14
update_interval: 5s
- platform: dallas
address: 0xE701202C5ADED628
- platform: dallas
address: 0xBE012115DCBEBC28
- platform: adc
pin: GPIO34
update_interval: 5s
attenuation: 11db
- platform: adc
pin: GPIO35
update_interval: 5s
attenuation: 11db
light:
- platform: fastled_clockless
chipset: WS2812B
pin: GPIO33 # Pin Define connected with LED strip
num_leds: 150 #LEDs number
rgb_order: GRB
effects:
- addressable_rainbow: ##defined 7 effects styles
- addressable_color_wipe:
- addressable_scan:
- addressable_twinkle:
- addressable_random_twinkle:
- addressable_fireworks:
- addressable_flicker:
KC868-A8/A4 http command list for third party software integration:
read relay state:
http://192.168.1.199/switch/switch1
control relay:
http://192.168.1.199/switch/switch1/turn_on
http://192.168.1.199/switch/switch1/turn_off
http://192.168.1.199/switch/switch1/toggle
read DI state:
http://192.168.1.199/binary_sensor/input1
read temperature:
http://192.168.1.199/sensor/temperature_1
read analog input:
http://192.168.1.199/sensor/analog-in1
read LED strip:
http://192.168.1.199/light/light_strip
control LED strip:
http://192.168.1.199/light/light_strip/turn_on
http://192.168.1.199/light/light_strip/turn_off
http://192.168.1.199/light/light_strip/turn_toggle
debug send command for TEST example: curl -X POST http://192.168.1.199/switch/switch1/toggle
