10-27-2020, 01:45 PM
Dear Support.
Is the away to ensure that NodeRed is running at all time?
Is there any changes i need to make on my laptop that will re-connect the NodeRed when it disconnect?
This is because once NodeRed stops the nodes are not able to update the IOS devices until the NodeRed is up and running again?
I have created a task schedule to automatically run NodeRed when the laptops starts but I notice once NodeRed disconnect it does not want to reconnect until i go into the schedule and re-run the task.
Will it be more stable if I use Raspberry Pi?
Thank You
Regards
Subas
Regards
Subas
