09-14-2025, 11:00 AM
Will it be possible to you can add in official FW support for recording the peak voltage, current, power and expose that through modbus registers? Plus add "clear peak values" modbus register where we can write a "1" to clear out the peak values. It would be great to monitor the spikes that can cause the breakers trigger. Also a great thing that implement for this type of devices would be support for LXI protocol so it could be used with software like this one: https://github.com/lxi-tools/lxi-tools
The peak values I think is most important here as it will be beneficial many users. The LXI support I will implement on my own but having it also out of the box would be beneficial.
Question regarding the ARM with modbus server, does it read the values from BL09010 in the loop or does it read for each request from modbus?
