10-11-2026, 04:29 AM
Thank you , i order new ssd . I made mistake first ssd was small sata ssd .i now order a SSD M.2 2242 NVMe. Keep you updated ✌️
SSD not visible for install home assistant in pi imager
10-11-2026, 11:46 PM
ok, good.
10-13-2026, 10:06 AM
new ssd is ok now , home assistant running . now next problem i face . mcp23017 in settings -> devices & services -> integations here i can't see MCP23017 Digital I/O Expander is not visible here whit me , then in Devices i can't see the chips .
10-13-2026, 10:13 AM
make sure enabled i2c bus for CM5.
i did , but i checked to be sure , and the map was gone ? so i did the steps agian ( making the maps , en file ) like in your tutorial . did restart the server .
home assistant is deleting the map that i made . is it beqause the Code is for the R32 Server and not the R16 server ??
ok step further . now i can switch output in home assistant , but the relay is not switching or the led of the output it's not lighting . so no switching .
Relay works now , i needed to put back the onnector for analog input ? now they trigger
10-13-2026, 01:16 PM
Yesterday, 05:42 PM
Every thing is working now ✌️
10 hours ago
ok, good.
| 1 Guest(s) |
