we have recorded many videos will help you.
1. How to wire? you need to know the hardware interface and diagram.
https://youtu.be/_EbfwEPhMUo
2. Config network setting,maybe you will use ethernet or WiFi.The default setting is "DHCP" by "UDP" work mode.
https://youtu.be/X3FSWfuWImg
3. How to install mobile phone app for remote control by cloud server.
https://youtu.be/FyPVUguU_h8
4. How to install mobile phone app for local control without internet.
https://youtu.be/xdWlEuIxOhA
5. How to use PC software for remote control by cloud server.
https://youtu.be/r-DN_30dNrg
6. How to use PC software for local control without internet
https://youtu.be/I2twUvE_C4o
7. How to use wall switch panel and wireless remoter for manual control
https://youtu.be/Qknel82vPOI
8. How to use voice control by Amazon Alexa speaker
https://youtu.be/t62vhuKnsr8
9. How to use voice control by Google home speaker
https://youtu.be/ShLsjd22oiU
10. If you already have one user account of mobile phone, but more people want to use.Then you can use grant authorization function to share deivce.(Note: one controller only can add to one phone account)
https://youtu.be/j2pb9JPJgZA
11. If you want to relay controller's input port trigger output. Such as input 1 -> relay1 ON,relay2 OFF.
step-1: create the scene for relay output actions. https://youtu.be/XzfLEUbYxI0
step-2: set input port trigger with which scene you have created.(Note:when you press relay for ON/OFF,must press the relay name text position when save) https://youtu.be/-JuWCZC39rY
12. If you want to relay controller's input port trigger for a alarm message send to all user.
