Interruptions from PCF8574
Is it possible to use interruptions on the I2C bus. As I understand, the pins of interruptions from PCF8574 is not connect anywhere.
Which ESP pin can be used to interrupt?
if you want to use, you can soldering a wire jump to ESP32's free pin.
