"KCS" firmware Modbus protocol document
Note: This protocol document use for KinCony ESP32 smart controller:
KC868-A4 KC868-A6  KC868-A8 KC868-A8S KC868-A16 KC868-E16S KC868-A32 KC868-A64 KC868-A128 smart controller
Different board will have different channel of digital output, digital input , ADC, DAC, so the protocol is same , just according to the hardware resource to set channel number.
.pdf   KC868-A-series-protocol-ModBus.pdf (Size: 139.11 KB / Downloads: 3,593)
How to read sensor in channel 1? Not a ADC. There is no in the documentation.
read sensor by RS485 modbus protocol? or MQTT?
which board model you are using?
(01-04-2025, 12:29 AM)admin Wrote: read sensor by RS485 modbus protocol? or MQTT?
by RS485. My board KC868-A6.
modbus not support read sensor by 1-wire port.
if you can write arduino code, you can define protocol by yourself.
(01-04-2025, 02:05 AM)admin Wrote: modbus not support read sensor by 1-wire port.
i see. okay. understand that. no problem for that. solved. just want to know why the sensor not state in the documentation.
Thank you.
