07-21-2024, 05:18 AM
We have designed ESP32 LoRa SX1278 Gateway - KinCony ALR. It support install into waterproof box. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with relay,SSD1306 LCD, 4 channel analog input, digital input, i2c bus extender, 1-wire GPIO, SX1278 LoRa module, DIP switch set for LoRa address.It can use for smart home IoT project use by home assistant. ESP32-S3 also support arduino IDE / MicroPython / ESP-IDF development tool.
![[Image: ESP32-LoRa-1.jpg]](https://www.kincony.com/images/ALR/ESP32-LoRa-1.jpg)
![[Image: ALR_diagram.jpg]](https://www.kincony.com/images/ALR/ALR_diagram.jpg)
Hardware resource:
Power supply: DC9-24V
USB-C: download firmware
Buttons: ESP32 Reset and Download
SX1278 LoRa module
Relay: MAX Load AC250v10A COM,NO,NC
SSD1306 i2c LCD
8bit DIP switch: set LoRa device address
Analog Input: 4 channel dc 0-5v signal
1-wire: 1 channel
digital input: 1 channel (dry contact signal)
I2C bus: 1
Hardware resource:
SX1278 LoRa module
SSD1306 i2c LCD
1-wire: 1 channel
I2C bus: 1
