10-14-2026, 06:49 AM
Good morning
I had to replace my kc868-H32B board (which worked for more than 4 years without problems) with the new kc868-32 board. The problem is that when I press the inputs a few times or turn the outputs on and off, the board loses connection (I observe this from the board's web server). The installed firmware is v2.2.14, and only the TCP server is active.
I had already reported this problem in the past with the kc868-a8 board and it seemed to be resolved, but that one also used to freeze often.
I can't understand where the problem is.
Do you have any suggestions or software to test this problem?
Thank you
Thank you
