Yesterday, 02:58 AM
* Description:
* This Arduino program reads ports 8-15 of an XL9555 I/O expander
* and prints their states to the Serial Monitor. The state of
* each pin is represented as a bit in a 16-bit value, where each bit corresponds
* to an input pin. The program prints the input state in binary format.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - XL9555 I2C Address: 0x22
#include "Arduino.h"
#include <Wire.h>
#include <PCA95x5.h>
// Define I2C pins
#define I2C_SDA 8 // Define SDA pin
#define I2C_SCL 18 // Define SCL pin
// Set I2C address
PCA9555 xl9555_IN1; // XL9555 driver object
#define I2C_ADDRESS 0x22
Wire.begin(I2C_SDA, I2C_SCL); // Initialize I2C with defined SDA and SCL pins
// Configure all ports as inputs; only ports 8-15 are read below.
xl9555_IN1.attach(Wire, I2C_ADDRESS);
xl9555_IN1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
xl9555_IN1.direction(PCA95x5::Direction::IN_ALL);
Serial.println("KinCony B8M 8 channel input state 0:ON 1:OFF");
// Keep ports 8-15 in bits 8-15, as in the original program.
// Bits 0-7 remain zero; do not shift the input states down.
uint16_t state = xl9555_IN1.read() & 0xFF00;
Serial.print("Input state: ");
Serial.println(state, BIN); // Print the state of inputs in binary
delay(500); // Delay 500ms
2-digital-input-9555.zip (Size: 929 bytes / Downloads: 15)
2-digital-input-9555.ino.merged.zip (Size: 194.13 KB / Downloads: 14)
