12-18-2023, 10:21 PM
KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome
12-18-2023, 10:45 PM
when you setup complete in PC config tool.
Do you have click the "ApplyTo" button and "SaveFlash" button? Must need press these two buttons.
12-18-2023, 10:58 PM
12-18-2023, 11:09 PM
can you post the newest yaml with latest KC868-HA component (v3.0.0).
12-18-2023, 11:13 PM
(12-18-2023, 11:09 PM)admin Wrote: can you post the newest yaml with latest KC868-HA component (v3.0.0). esphome: name: dingtian-4ch friendly_name: dingtian-4ch esp32: board: esp32dev framework: type: arduino # Enable logging logger: baud_rate: 0 # Enable Home Assistant API api: encryption: key: "XXX" ota: password: "XXX" status_led: pin: number: GPIO15 inverted: true uart: id: myuart1 tx_pin: GPIO1 rx_pin: GPIO3 baud_rate: 9600 ethernet: type: JL1101 mdc_pin: GPIO23 mdio_pin: GPIO18 phy_addr: 0 clk_mode: GPIO17_OUT # The PHY chip has a pin labeled TX_EN that goes to GPIO 21 on ESP # and the RSTn pin on the phy goes to GPIO0 ## # Datasheet indicates the RSTn should be LOW to disable the phy and default is high power_pin: GPIO0 external_components: - source: type: git url: https://github.com/hzkincony/esphome-kc868-ha ref: main kc868_ha: binary_sensor: - platform: kc868_ha target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software name: "binary_sensor 1" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 2 name: "binary_sensor 2" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 3 name: "binary_sensor 3" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 4 name: "binary_sensor 4" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 5 name: "binary_sensor 5" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 6 name: "binary_sensor 6" switch: - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 1 name: "switch 1" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 2 name: "switch 2" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 3 name: "switch 3" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 4 name: "switch 4" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 5 name: "switch 5" - platform: kc868_ha target_relay_controller_addr: 1 switch_adapter_addr: 10 bind_output: 6 name: "switch 6"
12-18-2023, 11:31 PM
- source: type: git url: https://github.com/hzkincony/esphome-kc868-ha ref: v3.0.0 use "v3.0.0" , you have use "main". change it. i don't know which esp32 board model you are using? i can't see in your photo. maybe you can exchange RXD and TXD pin define. Now do you INPUT port for binary sensor work well? only OUTPUT can't work?
12-18-2023, 11:50 PM
(12-18-2023, 11:31 PM)admin Wrote: external_components: I started with “ref: v3.0.0” and changed it to “ref: main” so I would always have the latest version. But it doesn’t work with either option anyway. The INPUT binary sensors work perfectly. If i press a button, it registers correctly in Home Assistant. It’s only the OUTPUT that doesn’t work.
12-19-2023, 02:41 AM
ok, later we check.
12-20-2023, 12:11 AM
after we tested, when have news, will feedback at here.
