06-26-2024, 08:07 PM
Hello.
I am interested in purchasing a KC868-A16 board to connect the programmable outputs (PGM) of a DSC Neo Alarm Center to the digital inputs (dry contacts) of the KC868-A16.
My question stems from the fact that the PGM outputs of the DSC Neo deliver a negative referenced to the 12v positive of the same board.
And to connect this directly to the KC868-A16 I would have to put a relay in the middle but this is not feasible.
The other solution is to know if I can disconnect the 12v from the KC868-A16 in the input optocouplers and directly insert the 12 from the DSC Neo.
Could you confirm if this is viable at the board level?
