Double/long click
Hi
One of your logic units (like KC868-COL) or the switch terminal board is able to detect double-click and/or long-click on the digital input from the self-reset switch? I would like to set it to perform some other action (like turning off a group of lights) without having a dedicated switch just for it. In other words: on a certain switch: (i) normal click would be programmed to do action_1, (ii) double click would do action_2; and (iii) long click would do action_3.
Thanks.
double click can't use now, hold-on click mode can be used, our customer already is using. There is hold on time for DI(digital input) set by COL PC software.
(06-22-2021, 12:48 AM)admin Wrote: double click can't use now, hold-on click mode can be used, our customer already is using. There is hold on time for DI(digital input) set by COL PC software.
Thanks.
I vote +1 for the double-click feature request  Big Grin
we are considering, maybe in furture will update firmware for double click action.
(06-23-2021, 12:19 AM)admin Wrote: we are considering, maybe in furture will update firmware for double click action.
I am waiting with interest
I hope it will happend soon
I hope you don't forget your existing customers. The update will also be to COL not just COLB
Best regatds
Stgen
which relay controller model you have use?
(07-07-2021, 11:30 AM)admin Wrote: which relay controller model you have use?
I have:
1)KC868-32
2)KC868-32B
3)KC868-COL
I would also be interested in the double click.
use COL + 2 h32L
now KC868-H32BS support double click mode.
